Advanced camera panning
COW Forums : Adobe Flash
Tyler Freeman
on Apr 22, 2012 at 2:25:06 am
I have the following code which lets me pan an image with mouse movement in a simultaneous x and y pan. (I will post my code following this post). I have made sure that my background image is a bit larger than my stage to account for movement. My results show the background moving upwards the top stopping nicely at the edge of the stage, however the bottom comes up just a little bit to far revealing bare stage. Why does the left and right work just fine but the up and down are screwed up. The "X" script is identical to the "Y" script. (with the exception of the x and y's).
Tyler Freeman
Re: Advanced camera panning
on Apr 22, 2012 at 2:25:40 am
My code:
import fl.transitions.Tween;
import fl.motion.easing.*;
import fl.transitions.TweenEvent;
var picTween:Tween
stage.addEventListener(MouseEvent.MOUSE_MOVE,mouseMoved)
function mouseMoved(e){
var yPercent = mouseY / stage.stageWidth;
var newYPos = (stage.stageWidth - pic.width) * yPercent;
picTween = new Tween(pic, "y", Circular.easeOut, pic.y, newYPos, 1, true);
var picTween:Tween
var xPercent = mouseX / stage.stageWidth;
var newXPos = (stage.stageWidth - pic.width) * xPercent;
picTween = new Tween(pic, "x", Circular.easeOut, pic.x, newXPos, 1, true);
demetri tashie
on Apr 26, 2012 at 2:34:47 pm
i would check the registration point of the image within the movieclip 'pic', as well as then the placement of the movieclip 'pic' on the actual stage.
