Sync Video to Audio
COW Forums : Adobe Flash
edgar scott
Sync Video to Audio
on Mar 26, 2012 at 2:18:10 pm
hey folks,
i'm a beginner in flash (cs 5.5) and just can't find a solution for the following issue:
basically i want to make a music-video, so audio is already specified (10min-file). now it's just a matter of editing the whole thing, as i want to animate different objects fitting the audio. if played from start everything's fine, but if i just choose to play from frame 2 (audio starts in frame 1) audio will not play and thus makes it nearly impossible to achieve the result i'm looking for, as i need precision down to one frame to make animations fit perfectly.
anyone got an idea?
any help would be greatly appreciated!
best regards,
edgar scott
Re: Sync Video to Audio
on Mar 26, 2012 at 3:31:10 pm
alright, just found it. should any other noob wonder:
sound's property got to be set to "stream" (select the layer where you placed the sound, properties, synchronisation "stream").
© 2018 All Rights Reserved
