swf can't show on my webste
COW Forums : Adobe Flash
Kumi Kwasi
on Nov 4, 2011 at 6:29:09 am
I created powerpoint document and converted it into swf using Ispring. I inserted it into my website. It showed perfectly when I tested it in a browser. But when I uploaded the entire site unto the internet it didn't show. Can somebody give advice here? What is the problem?
Thanks, Kumi
demetri tashie
Re: swf can't show on my webste
on Nov 6, 2011 at 7:52:19 pm
That usually indicates a path issue.
First, is the SWF really uploaded to the server, along with all the other needed files? does your HTMl file have the correct path to the SWF? check that it doesn't actually indicate some local computer path instead ( which word work as you test it locally), rather than the correct server directory path to where it can actually be found.
© 2018 All Rights Reserved
