COW Forums : Adobe Flash
Flavia Burza
on Oct 6, 2011 at 2:42:19 pm
Hello,
I have have a .fla file that I need to export to a .gif. When I try to, in Publish settings, only one static img is exported and not my whole animation (scene). How can I create .gif from my .fla without this happening or how can I convert my .swf to a .gif?!?!
My animation is composed of movieclips inside movieclips that are on layers on my scene.
I need help ASAP!
Thank you.
demetri tashie
Re: Converting a .swf to .gif
on Oct 7, 2011 at 6:23:05 pm
got to
File --> Publish Settings and make sure you check 'GIF Image (.gif) and choose your file name and destiantion folder.
from the GIF tab now available in the dialog box, choose 'GIF', and in the 'Playback' options, make sure 'Animated' is checked off rather than 'Static' which may be the default box checked.
Click 'OK' , and then publish your file and it should run as an aniamted GIF
