Flash only works when on test mode but not in Live view - Dreanweaver CS5.5
COW Forums : Adobe Flash
Gary Acosta
on Aug 22, 2011 at 2:46:59 pm
I'm trying to embed a flash on html and I can't get it to work. Below is my code:
<!-- flash content here -->
It works when i removed this code:
Carey Burgess
Re: Flash only works when on test mode but not in Live view - Dreanweaver CS5.5
on Aug 30, 2011 at 12:57:27 am
Hi Gary,
Your code is not showing up, but my guess is that the SWFVERSION within the code may be set to a non-existent version of Flash Player.
Check in the code for two instances of the "swfversion=" parameter (<param> tag), and that is where you will find this.
If it says anything after 10.3.x.x, then change it to something lower (e.g. 8.0.0.0 or 10.0.0.0).
If that doesn't help, then please encode your HTML before pasting it into your reply.
There are several HTML encoders out there if you are not familiar:
http://www.google.com/search?q=encode+html
