ActiveX control for Flash Player could not be registered
COW Forums : Adobe Flash
Joe Bodego
on Aug 12, 2011 at 1:32:31 am
I am in need for some serious help before i have to do the ultimate and reformat my hard drive and spend the next 12 hours reinstalling everything. The issue is flash. I get this error "ActiveX control for Flash Player could not be registered" anytime i tru to install flash. I can see flash content in every browser except internet explorer 9 so I don;t know what to make of this. I have tried everything to now avail. There are a few programs that won;t work and always prompt me to install flash. When I do I get the same error. The fact that this error can;t be fixed is amazing to me. I am asking has anyone got any idea on how to fix this problem minus the usual links that Adobe has, none of their remedies work. I am using windows 7 64 bit
Carey Burgess
Re: ActiveX control for Flash Player could not be registered
on Aug 30, 2011 at 1:13:18 am
Hi Joe,
I know you said you didn't like our resources, but I highly suggest checking out this article:
http://adobe.ly/KB19166
I recommend starting by running the Flash Player uninstaller (#3) and then check security settings (#4).
If still not working, then you don't have access permission to one or more of the necessary registry entries or folders. More info on this near the bottom of the above document: http://adobe.ly/KB19166#main_CommonErrors
Hope this helps!
