CS5 audio export issue
COW Forums : Adobe Flash
Graham White
on Aug 2, 2011 at 6:45:48 pm
I have found that changing the export settings in the audio properties panel does not properly set the audio compression on publication. No matter what setting I use, I get a file of exactly the same size. I do not have override sound setting checked in publish settings.
The only way that the audio export setting can be changed is to make the change in the Publish setting dialog.
This worked properly in CS3, but seems to be an issue in CS5.
Can anyone shed any light on this issue?
Graham White
© 2018 All Rights Reserved
