Flash 5.5 Question/Problem
COW Forums : Adobe Flash
joseph wilkins
on Jul 23, 2011 at 5:30:05 pm
Hello...
So I have a flash movie (well.. my website is one big flash movie) and I just upgraded to CS5.5.
I opened my movie to make a change, and now when I export it, a curious thing happens...
If you go to http://www.pro-creative.com/Promo.html and click on the "Contact Us" link, the form that up until now has worked fine, now will not allow you to type in 7,8,9 or 0!!!
It will let you type 1,2,3,4,5,6 and all the letters of the alphabet.
It also will not let you type in the @ sign... so I cannot capture email addresses.
It works fine in the version I created in flash 4... see http://www.pro-creative.com
Can anyone tell what is causing this odd behavior?
Thanks so much
demetri tashie
Re: Flash 5.5 Question/Problem
on Jul 23, 2011 at 5:52:10 pm
first thing you should check:
since you are using version 5 (or above), make sure you embedded the font for those fields.
