Can't disable grid
COW Forums : Adobe Flash
Michael Paul
Can't disable grid
on Jul 3, 2011 at 4:50:55 pm
For some strange reason flash CS5 suddenly has to display a grid for me even tough grid is turned off. It doesn't matter if I turn it on/off- it makes no difference at all. The grid will still be displayed.
What I did: I've installed "2d virtual camera cs" with the CS5 extension manager. That thing wouldn't work tough so I've first disabled it and later removed it. I am only assuming that this gave me the grid problem because CS5 always worked fine and never gave me a grid before.
Is there any ini file or something where I can edit a value to just turn off the grid or is there any other solution because I find the grid to be pretty annoying.
