flash error
COW Forums : Adobe Flash
fionnlagh ballantine
flash error
on Jun 6, 2011 at 9:52:12 pm
Hello,
I followed a youtube video to create a 3D page flip in flash, the video is for cs4, i'm using cs5, maybe that is the problem. this is the url.
this is my actionscript, using actionscript3,
import fl.transitions.Tween;
import fl.transitions.easing.Strong;
import fl.transitions.TweenEvent;
import flash.events.Event;
con.sidea.flip.addEventListener(MouseEvent.Click,onflip);
con.sideb.flip.addEventListener(MouseEvent.click,onflip);
addEventListener(Event.ENTER_FRAME,loop);
var isStill:Boolean=true;
var arraytween:Array = new Array();
function onflip (e:Event) {
if (isStill) {
arraytween.push(new Tween(con,'rotationY',Strong.easeOut,con.rotationY,con.rotationY+180,1,true));
arraytween[0].addEventListener(Tween.MOTION_FINISH,reset);
isStill=false;
function reset(e:Event) {
isStill=true;
arraytween=[];
function loop(e:Event) {
if (con.rotationY>90 && con.rotationY<=270) {
con.addChild(con.sideb);
con.scaleX=1;
} else {
con.addChild(con.sidea);
con.scaleX=1;
if (con.rotationY>=360) {
con.rotationY=0;
there were no problems until I tested the movie clip, the button didn't work and these three messages appeared, my button didn't work andI don't know why.
Scene1, larger'as3,frame1,line18 1119;access of possibly undefined property MOTION_FINISH through a reference with static type class
Scene1,layer'as3,frame1,line6 access of possibly undefined property Click through a reference with static type class
scene 1,layer'as3,frame1,line 7 1119:access of possibly undefined property click through a reference with static type class
demetri tashie
Re: flash error
on Jun 7, 2011 at 5:15:35 am
the first problem is that your MouseEvent Listeners need to have the event 'CLICK' written in capitals.
you have it as:
and it should be:
con.sidea.flip.addEventListener(MouseEvent.<b>CLICK</b>, onflip);
con.sideb.flip.addEventListener(MouseEvent.<b>CLICK</b>, onflip);
the second is you have two things wrong in your conditional . first condition should be greater than or equal to 90, not just greater than 90 , and the second thing is your assigning con.scaleX value in the first condition should be negative one not positive one
you had:
if (con.rotationY<b>>90</b> && con.rotationY<=270) {
con.scaleX<b>=1</b>;
and it should be:
if (con.rotationY<b>>=90</b> && con.rotationY<=270) {
con.scaleX=<b>-1</b>;
the third problem is the event calling the reset function is a TweenEvent,not a Tween. you had:
arraytween[0].addEventListener(<b>Tween</b>.MOTION_FINISH,reset);
and it should be:
arraytween[0].addEventListener(<b>TweenEvent</b>.MOTION_FINISH,reset);
if you fix those mistakes, it will work as expected. you really do need to be exacting and careful when writing, and especially when copying or transcribing, code.
hope that helps
