Age verification
COW Forums : Adobe Flash
Jessica Chapman
Age verification
on May 3, 2011 at 12:56:00 pm
I am complete n00b at flash. :(
I am using a actionscript 3 class for an age verfication that I followed from here:
http://active.tutsplus.com/tutorials/actionscript/develop-an-age-verificati...
I have turned the age verification into a movieclip and have linked the age verification class to it.
On my main timeline:
Frame 1 has a pre-loader.
Frame 2 is the age verifcation movieclip.
Frame 3 is the main movie clip with all the content inside.
What I have been trying to do, is find a way so that once the 'enter' button of the age verifcation movieclip is clicked, it will proceed to frame 3 on the main timeline, which will play that movieclip.
Any help would be so very much appreciated! :'(
sri kanth
Re: Age verification
on May 3, 2011 at 1:08:32 pm
just call the nextFrame() or play(), but if you can post your code, it will be easy to analyse and guide you the best
Jessica Chapman
on May 3, 2011 at 1:20:54 pm
Here is the code I'm using for the validator:
package
import flash.display.Sprite;
import flash.events.MouseEvent;
import fl.transitions.Tween;
import fl.transitions.easing.Strong;
import fl.transitions.easing.Back;
import flash.net.URLRequest;
public class Main extends Sprite
private var tween:Tween;
private var minimumAge:int = 18;
private var tooOldAge:int = 130;
private var months:Array = ["Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec"];
private var currentDate:Date = new Date();
private var userBirth:Date;
private var userAge:Number;
public function Main():void
tween = new Tween(panel,"y",Strong.easeOut, - panel.height,stage.stageHeight / 2,0.5,true);
panel.enterButton.addEventListener(MouseEvent.MOUSE_UP, verifyAge);
private function monthToNumber(month:String):int
var monthNumber:int;
for (var i:int = 0; i < months.length; i++)
if (panel.monthField.text == months[i])
monthNumber = i;
return monthNumber;
private function verifyAge(e:MouseEvent):void
userBirth = new Date(int(panel.yearField.text),monthToNumber(panel.monthField.text),int(panel.dayField.text));
userAge = Math.floor((Number(currentDate) - Number(userBirth)) / (1000*60*60*24) / 365);
if (userAge > tooOldAge)
panel.messages.textColor = 0xAA0000;
panel.messages.text = "You can't be " + userAge + " years";
else if (userAge >= minimumAge)
panel.messages.textColor = 0xF2DC57;
panel.messages.text = "WELCOME";
tween = new Tween(panel,"x",Back.easeIn,panel.x,stage.stageWidth + panel.width / 2 + 10,0.3,true);
loadContent();
else if (userBirth.getFullYear() > currentDate.getFullYear())
panel.messages.text = "Are you from the future?";
else
panel.messages.text = "You must be " + minimumAge + " or over";
redirect();
private function loadContent():void
private function redirect():void
//navigateToURL(new URLRequest("http://www.tutsplus.com"));
On frame 1 of the timeline I just have a preloader script which works fine.
On frame 2 I have stop(); so that once the preloader has loaded it stops at the validator movieclip on frame 2.
On frame 3 I have stop(); with the main movieclip.
Hope that makes sense. I would really appreciate where to exactly place the coding, I'm pretty dumb at this sorry ><
sri kanth
on May 3, 2011 at 4:46:11 pm
you should put the code - "nextFrame()" or "play()" in the second condition of the function "verifyAge()". Since it is calling "loadContent()" you can place the code inside loadContent();
To finalize or rather decrease the complexity explained above, just put play() inside loadContent()
Jessica Chapman
on May 3, 2011 at 8:25:24 pm
Sorry for being a complete n00b but...
would I place "play()" here...
play()
or place it at the first loadContent reference?
loadContent(play());
I'm guessing I'm completely wrong as neither of these work... :S
sri kanth
on May 4, 2011 at 5:17:19 am
I have uploaded the source files (needs flash cs5, however it will work if you replace the main.as though). Password for the uploaded files is "srikanth".
2302_ageverification.zip
Jessica Chapman
on May 4, 2011 at 8:48:37 am
Wow thank you very much! :D Just wondering, if I wanted to add some more frames to the timeline, how would I adjust it so that it doesn't stop at just the next frame, but plays through?
I'm guessing I would have to change (parent as MovieClip).nextFrame(); to something else?
sri kanth
on May 4, 2011 at 9:29:04 am
yes! just change it to
(parent as MovieClip).play();
if specific frame then use - (parent as MovieClip).gotoAndPlay();
any queries mail me srikanth[dot]mx[at]gmail[dot]com or post at my "forum.websibblings.com"
Jessica Chapman
on May 4, 2011 at 11:15:51 am
Awesome!! Thank you sooo much for helping me out!!! ^____^
sri kanth
on May 4, 2011 at 11:41:34 am
welcome
srikanth
http://www.websibblings.com
