Unable to send complex input data to WSDL method
COW Forums : Adobe Flash
Supriya Tenany
on Mar 22, 2011 at 9:00:57 am
I am unable to use a WSDL method when I try to send complex data as input. I am able to receive and use response for operations requiring simple inputs, but unable to send complex data inputs.
The operation to be called is in the following format:
The AS 2.0 code is:
[CODE]
import mx.services.*;
import mx.remoting.*;
import mx.rpc.*;
import mx.data.*;
var paramObject = new LoadVars();
paramObject.mobileObj.mobileId = "1234";
paramObject.mobileObj.mobileCode = "N";
paramObject.emailId = "supriyaakg@test.com";
paramObject.userPassword = "test123";
var myWebServiceObject = new WebService("http://abc/mobile_servicesSOAP?wsdl");
myWebServiceObject.onLoad = function()
trace("Success call for WSDL");
var MyPendingCallObject:PendingCall = myWebServiceObject.loginUser(paramObject);
trace("----" + MyPendingCallObject.request);//input data format
MyPendingCallObject.onResult = function(result)
trace("----" + MyPendingCallObject.response);//output data
MyPendingCallObject.onFault = function(fault:PendingCall)
trace("Fault = " + fault.response);
myWebServiceObject.onFault = function(fault)
trace("Oops!!!" + fault);
[/CODE]
