Input Text won't work through Dreamweaver
COW Forums : Adobe Flash
Chris Lupetti
on Feb 23, 2011 at 3:00:38 am
Hello,
I am making a contact form with Flash CS3, AS2 and PHP. Right now I am running into a problem. When I publish my Flash website through Dreamweaver the input text field will not work. This is probably because I am loading this external swf (that has the input text on it) into the main swf. However, when I import the swf that has the input text alone into Dreamweaver (without loading it into another swf) the input text works.
The ActionScript and PHP can be viewed on this tutorial.
http://www.macromediahelp.com/flash/php_flash_contact_form/
Thanks for your help.
