can't make movie clip in timeline stop
COW Forums : Adobe Flash
Emily Carmichael
on Feb 10, 2011 at 5:35:01 am
Hi guys,
I'm trying to stop a movie clip, and it's just not working. I've checked a bunch of manuals, and I still can't for the life of me figure out what I'm doing wrong.
The scene starts like this: http://kidcandrive.com/Scene7.swf
When the characters stop, the walls are supposed to stop. So....
cavey.stop();
where cavey is the name of the instance of the movie clip that is the moving walls. Why on earth is it not working? I've used the same command in a different context and it works fine.
Sometimes I get this error:
1120: Access of undefined property cavey.
But cavey is the name of the instance!!
Thanks in advance for your help.
Brodd Nesset
Re: can't make movie clip in timeline stop
on Feb 10, 2011 at 7:28:11 am
Check that you haven't by mistake, set the original MovieClip to be a Button type element in the properties panel (just below the instance name field). Buttons can (should / must) also have instance names, but they do not support the stop(); command.
This has happend to me more times than I'd like to mention * 10.
Not everything that can be counted counts, and not everything that counts can be counted.
