AS3 button to activate browser back button?
COW Forums : Adobe Flash
Mary Waitrovich
on Feb 9, 2011 at 7:04:02 pm
Is it possible to make a button in AS3 that activates (or does the same thing as) the browser's back/forward buttons? If so how?
Thanks much,
Mary Waitrovich
Media Plus You, LCC
http://www.mediaplusyou.com
Mike Smith
Re: AS3 button to activate browser back button?
on Feb 9, 2011 at 9:33:32 pm
To do this you have to communicate from your swf the browser, using Actionscript to call a javascript function. There are different ways of communicating with the browser ; if programming is your thing this may get you started http://codingrecipes.com/calling-a-javascript-function-from-actionscript-3-...
or this might give a bit more depth.
http://books.google.co.uk/books?id=WiedhiREmZkC&pg=PA478&lpg=PA478&dq=AS3+b...
This might get you started on javascript to back button, if you need it. http://www.exforsys.com/tutorials/javascript/javascript-history-object-prop...
demetri tashie
on Feb 10, 2011 at 3:15:03 am
exactly. externalInterface is the way to go if you want to emulate the 'back button' of the browser.
this simple code makes it work.
in flash:
import flash.external.ExternalInterface;
function myAS3function(event:Event):void {
ExternalInterface.call("goBack");
and in your html ( with in script tags in the head )
function goBack(){
history.go(-1);
where -1 takes you back 1 page in your browser's history.
