XML Marquee text
COW Forums : Adobe Flash
Fred Mirtz
XML Marquee text
on Feb 2, 2011 at 9:52:20 pm
I am having trouble finding information on how to make my flash horizontal scrolling text marquee changed over to an XML driven one.
COuld someone help by pointing me to a tutorial or something that I could use to make a text marquee that can be used by loading from an xml file?
Mike Smith
Re: XML Marquee text
on Feb 4, 2011 at 11:39:11 am
So the marqee part isn't stressing you.
So you want to use a variable to hold your marquee text.
Then you need to load an xml file and put data from it into your variable.
XML is handled quite differently in AS2 and AS3.
This should help with AS3
or this might help if you are on AS2
© 2018 All Rights Reserved
