return to links
COW Forums : Adobe Flash
Steven Allen
return to links
on Jan 31, 2011 at 7:45:26 pm
Hello,
Using Flash CS5 and action script 3.0 I have made two scenes. The buttons and links work fine in Scene 1 and I have set up a frame event in Scene 2 that takes you back to frame 1 of Scene 1 when Scene 2 ends. It works fine except that when it goes back to Scene 1, the buttons and links no longer function. Any ideas?
demetri tashie
Re: return to links
on Jan 31, 2011 at 9:08:30 pm
where is your code? is it on that first frame of Scene 1 that it goes back to ? it would need to be there.
other than that it is hard to say without more info or code. know that Scenes can be buggy, and really haven't been used seriously in a while. If you must use timeline based navigation, it might be better to put it all on one continuos timeline and see if that makes a difference.
if you are stillhaving trouble, write back with more info and description
