Exporting as Quicktime from Flash CS4
COW Forums : Adobe Flash
Aaron Roy
on Jan 29, 2011 at 7:29:15 pm
Having frame rate issues exporting a Quicktime movie from Flash CS4. My flash document is set to 30fps and the frame size is 720p. All exports have been cutting the frame rate in half (i.e. 30fps to 15.15fps).
Tried rendering again this morning and got 29.72fps, from setting my QT export to use whatever the flash document is using.
I've tried three different QT exports...
1) 720p with the 'current' frame rate (Animation Codec)
2) 720p with 30fps (Animation Codec)
3) 720p with 29.97fps (Animation Codec)
On a MBP laptop 2.93 core due, 4g RAM,
Also tried exporting with AppleProRes, frame rate was right... but my alpha channel was lost. Bah, what's going on?
-more info
When I export I get a warning saying that quicktime must change its frame rate to match the flash document... Even though quicktime is set to 'current'
© 2018 All Rights Reserved
