Writting and reading file
COW Forums : Adobe Flash
Marc Poirier
on Jan 28, 2011 at 8:21:46 pm
Hi all,
I'd like to know how I can write info to a file on the ipad and retrieve it afterwards (to keep count of the answers)
thx
Marky
Mike Smith
Re: Writting and reading file
on Jan 29, 2011 at 11:16:25 am
Why would you ask an iPad question in a Flash forum ?
Marc Poirier
on Jan 29, 2011 at 2:40:08 pm
BECAUSE i DEVELOP IPAD APPLICATIONS WITH CS5 (FLASH)!!!
WHICH IS A FLASH QUESTION..
Marky
Mike Smith
on Jan 29, 2011 at 4:03:17 pm
So you know about reading and writing local files with the FileReference.Load and FileReference.Save but you want to know if that is supported in the rewrite from AS3 to iOS native code ..? Why not test it?
http://www.adobe.com/devnet/flash/quickstart/filereference_class_as3.html
Marc Poirier
on Jan 29, 2011 at 4:08:35 pm
Mike..
If you don't want to help and just want be cocky, then you should find yourself other blogs on the internet who will accept this behavior..
I have never used file reference, nor have I mentionned knowing how to use it...
if someone knows how to do it and have code snippets that works, then this is what I'm looking for..
I have to deliver tomorrow, and if I can save all the R&D for now that's my goal..
If you can't help, don't respond pls.
Marc.
Marky
Bhavesh Savla
on Apr 25, 2011 at 9:20:05 am
Hi Marky,
I am running into the same problem as yours. I am not able to save image from flash to ipad. The application is running perfectly fine on desktop, browser, Samsung Galaxy Tab (Android). But not on iPad.
When I click on Save button in my application which initiate fileReference.save - nothing appears. Usually Native file save dialoge box appears. But this is not the case in iPad.
So, i can say that its not possible to save image from flash to iPad as local file.
If anyone come across such situation and able to crack this, please post here.
Thanks in advance.
Regards
Bhavesh Savla.
