contentPath, unable to enter/change path
COW Forums : Adobe Flash
Stephen Waddock
on Dec 22, 2010 at 1:14:35 pm
Version: CS5
In CS4, I can use contentPath in the Components Inspector to point to my .flv so I can run, test my file locally. After confirming all works well, I then change that path to point to the .flv which has been uploaded to the server where it will live in Prod.
Normally, I get the error regarding live stream but, it allows me to enter regardless.
The problems now is, in CS5, I am unable to edit/change that path once I get that same error.
I know I can do this in AS but, I should be able to do this in the contentPath in the Components Parameters dialog.
Is this a known bug?
Any help would be greatly appreciated.
© 2018 All Rights Reserved
