Extract Audio from SWF
COW Forums : Adobe Flash
Clint Milner
on Nov 27, 2010 at 2:38:17 pm
Hi All,
I found a swf from probably 5 years ago that I made with some buddies of mine back in uni and it's just a timeline animation that has an audio track running with it.
I wanted to put it on YouTube, so I tried bringing it into After Effects, but there was no audio and the movie clips inside the SWF weren't working. (ie: the timeline moves along, but character's leg animations which were movie clips don't work)
What's the best way to take this SWF and convert it to a video with audio?
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
Brodd Nesset
Re: Extract Audio from SWF
on Nov 29, 2010 at 9:45:55 am
Try and bring the old SWF into the Flash Authoring tool, and place it on the Stage.
Use File / Export (not 'Publish'), and select / Export Movie. Here you can choose a variety of formats, for instance AVI and MOV (Quicktime). Even WAV - if it's only the audio you want.
This will effectively create a screen capture of every frame playing; including MovieClips and of course Audio too.
The performance of this function used to be a little ho-hum in Flash before, but it's said it's been improved now. I haven't tried it myself.
Onother option is of course to use simply a dedicated screen capture program.
Not everything that can be counted counts, and not everything that counts can be counted.
Clint Milner
on Nov 29, 2010 at 3:28:56 pm
Hi Brodd,
Thanks for the reply. It's not working for my swf, but I can see it working for other people.
The movie clips didn't get imported so there's no animation and the sound isn't there either, but I think what I'll try next is to do a screen and audio capture.
This might be the best way because since it's all vector, I can size it up and get a better resolution for YouTube video.
Kind Regards,
Clint
12 GB DDR3 RAM
4 TB RAID 5
