Transform an after 1080x1920 comp into a FLA file. XFL crash
COW Forums : Adobe Flash
Renato Silva
on Nov 19, 2010 at 6:17:24 pm
People all over the world,
I need your help! My problem is the following:
I need to transform an AE comp into a FLA file. The comp is 1080 by 1920 (vertical) and I tried to use the XFL file but I get a 1080 by 1080 FLA file when I open the XFL in Flash.
I tried in AE to export a sequence of PNG to import it into FLASH inside of a movie clip, but I only can do this on the first 100 frames then it crashes all the time.
What can I do?
PLEASE HELP! I WILL SEND YOU A PAIR OF HAVAIANAS from Rio de Janeiro.
Thanks a lot!
