When I click button... I want my video to stop
COW Forums : Adobe Flash
joseph wilkins
on Nov 5, 2010 at 8:09:48 pm
So I have a simple flash movie that autoplays a video when you open a page.
The video is using the FLV playback component.
For complex reasons, I do NOT want to have a skin on the video that plays, but I want to have a button on the page that when clicked stops the video playing... so I need to target the video component with the button.
Can this be done?
Thanks.
demetri tashie
Re: When I click button... I want my video to stop
on Nov 5, 2010 at 11:41:57 pm
are you talking about a custom button in the swf or a button outside of the swf in the html to control/stop the video component?
either way can be done but they are coded very differently
joseph wilkins
on Nov 6, 2010 at 1:34:26 am
Just a regular button on the page that when clicked stops the video
demetri tashie
on Nov 6, 2010 at 1:39:16 am
INside or OUTside the SWF ?????
joseph wilkins
on Nov 6, 2010 at 1:44:43 am
Oh... Inside the same swf
demetri tashie
on Nov 6, 2010 at 2:03:44 am
ok, that is very easy.
you can either just drag out a stop button from the Components Panel ( it is under Video )
and with nothng else, it will know to be asociated with the instance of the FLVPlayback component you are using.
if you want a more custom button, you will need to add an event listener to the button to trigger the stop function of the video player:
myButton.addEventListener(MouseEvent.MOUSE_DOWN, stopVideoFunction);
function stopVideoFunction(evt:MouseEvent):void
myFLVPlaybackComponent.stop();
joseph wilkins
on Nov 6, 2010 at 2:12:45 am
So the stop component sounds great... but how will it know which video to stop?
Just to clarify would you please look at the page I am trying to fix...
http://www.pro-creative.com
enter the site and click on the "Corporate Video" link.
The talking guy is the video I want to stop playing as soon as someone clicks on one of the video examples below.
So given this... how would I use the stop component?
Thanks sooooooo much for your help!
demetri tashie
on Nov 6, 2010 at 3:32:34 am
then make sure the component stop button has an instance name - say it is "compStopBtn"
then just declare it to be associated with whatever video player componet you want it to control:
flvPlayer2.stopButton=compStopBtn
the above code would have it associated with flvPlayer2
hope that helps
