Changing video source outside swf file
COW Forums : Adobe Flash
Luke Brown
on Oct 11, 2010 at 11:04:19 pm
Hello everyone,
I have been looking for two days straight on how to do this, and I can't seem to find anywhere to start....
I have created a simple video player within my flash project (actionscript 3, CS5). It works great, and plays MP4 video that I link within Adobe Flash. However, I need to change the video source of the player outside of the swf, preferably with HTML, PHP, or java-script.
This would work a lot like the cookie cutter flash players that can be downloaded, embedded, and then passed a parameter from HTML with the video source location. None of the pre-built players online work really well for what I need.
Any help or recommendation on how to go about accomplishing this would be greatly appreciated.
Thank you! :-)
Brodd Nesset
Re: Changing video source outside swf file
on Oct 12, 2010 at 7:21:34 am
- Create a 'myURL' string variable.
- Fetch the content of 'myURL' (the actual URL of the video) with JavaScript or FlashVars embedded in the HTML.
- With scripting, you can override the source URL set with the Playback Component, and set it it 'myURL' instead.
Here's a source I found for JavaScript <-> Flash intercommunication.
You don't need to use buttons / interactivity of course; just call the JavaScript like suggested. This is one of the simplest (in a positive sense!) variations I've seen.
Not everything that can be counted counts, and not everything that counts can be counted.
© 2018 All Rights Reserved
