Event Listener actionscript 3.0
COW Forums : Adobe Flash
Neha Gandhi
on Aug 28, 2010 at 2:18:07 am
Hi guys,
I have one as 3.0 class called WSManager class, which looks like below:
import mx.rpc.soap.*;
import mx.core.*;
import flash.display.*;
import DeviceVO;
public class WSManager extends Sprite
private var _ws:WebService;
private var _data:Vector.<DeviceVO > ;
public function WSManager()
_ws = new WebService();
public function load(wsdl:String):void
_ws.wsdl = wsdl;
public function setOperation(oper:String, deviceName:String):void
var myOperation:Operation;
myOperation = Operation(_ws.getOperation(oper));
myOperation.addEventListener(FaultEvent.FAULT, wsFault);
myOperation.addEventListener(ResultEvent.RESULT, wsResult);
private function wsResult(evt:ResultEvent)
// initialize vector
_data = new Vector.<DeviceVO>();
// declare variables
var vo:DeviceVO;
var device:Object;
// iterate results
for each (device in evt.result.Devices)
vo = new DeviceVO();
// this is the same as using _data.push()
// but this is more performant code
_data[_data.length] = vo;
// dispatch this event to let your .fla file know
// all the data has been loaded successfully.
trace("Dispatch event from WSManager class......");
dispatchEvent(new Event("dispatch"));
private function wsFault(evt:FaultEvent)
trace('something went wrong...');
public function get data():Vector.<DeviceVO>
return _data;
public function set data(data:Vector.<DeviceVO>):void
_data = data;
Then i have another GUI class called demo2_as3.fla which calls WSManager class to extract all the data from it. The code is below:
var _ws:WSManager=new WSManager();
_ws.setOperation("GetDeviceInfo", "");
_ws.addEventListener("dispatch", dataReadyHandler);
The problem that i am stuck on is the WSManager class keeps on tdispatching event again and again, which keeps on refreshing the dataReadyHandler() in demo2_as3 class. I am stuck in a loop. I am unable to do anything.
Could anyone tell me, why WSManager keeps on dispatching events like every 8 sec. Can we stop it and restrict to only dispatch.
© 2018 All Rights Reserved
