Multiple classes
COW Forums : Adobe Flash
Shuyin Kagerou
Multiple classes
on Aug 17, 2010 at 1:40:45 pm
Hello peope of Creative Cow.
I made a slideshow application in which events are loaded through xml.
all events have their own slideshow and description panel.
in te slideshow i want to show the total nr of images and what image your on now like:
1 /6, 2/6, 3/6 etc.
the app consists of a AS3 class and a seperate class for the slideshow called
the main class has all the code and can access the dynamc text field where the data is supposed to go.
the class has the code to get the numbers needed to dynamically show the number of images per event.
what I want to do is, get the data I get from to output in the scene..
the place it needs to go is "bannerRotatorContainer.pos_txt".
but does not recognise this (not even with root.container.bannerRotatorContainer.pos_txt
so I made it simple in
if I trace:
I get the number of which image it reads now.
if I trace:
I get the total number of images in that event.
How can I get these variables to work in
I hope you guys udnerstand what I mean :D
© 2018 All Rights Reserved
