smooth effects tweening
COW Forums : Adobe Flash
Aaron Hayman
on Jul 28, 2010 at 11:48:55 pm
Hey there,
I'm working on a project in Flash CS4 and I've got a part where I'm using the "glow" effect to put a sort of white halo around an object. The problem is, is that I want to have that halo smoothly grow over the course of about 30 frames (at 30 fps) and the action is far from smooth. What happens is that about 50% of the glow affect happens over the initial 29 frames and then the very last frame the glow "jumps" 50% in brightness. I want the effect to come on gradually and am bothered by this jump that happens on the very last frame of the tween. Is there anything that can be done about this? I might add that I've messed with the easing in and out and that doesn't seem to have any effect.
demetri tashie
Re: smooth effects tweening
on Jul 29, 2010 at 12:02:10 am
hi aaron,
i would really suggest to not use the built in glow filter, but to use TweenLite by greensock ( http://www.greensock.com/tweenlite/ ) and have the effect happen over time, rather than over frames. you will experience a much better, smooth effect that way.
