Issues with Movie Clips
COW Forums : Adobe Flash
shawn rice
on Jul 26, 2010 at 1:41:07 am
Hi. I am attempting to generate a simple site using Flash 10 and AS3.
The example can be viewed here:
I have 7 navigation buttons along the left side of the stage, all with varying colors.
Clicking any of the buttons triggers the color of the button to bleed out over the stage, eventually covering the background color so it matches the color of the button.
I am using AS to go to frame X and play, with a stop frame at the end of the animation (once the color has covered the entire stage).
(Button 1 triggers an animation which runs from frame 2 to 32, Button 2 triggers an animation which runs from 33 to 63, and so on...)
For instance, the default background color is a dark grey, and when I click on the green button, a green circle grows until it is larger than the stage, making the background green.
The issue that I am having is when you click on a second button, the background returns to the default (grey) and then runs the animation.
I would like the animation to play over the last frame of the current section.
I think movie clips might be the answer, but I couldn't configure the buttons to trigger them.
Any assistance would be greatly appreciated,
© 2018 All Rights Reserved
