Keyframes to Symbol?
COW Forums : Adobe Flash
Camren Banks
on Jul 19, 2010 at 4:47:42 pm
I've created a simple keyframe animation, hand writing effect.
Was wondering if there was a way to take all those key frames and group them together? So that I can change the size/color of the image without having to changed each and every frame.
Best
Cam
Jen deHaan
Re: Keyframes to Symbol?
on Jul 19, 2010 at 5:52:59 pm
You can either put the frames into a movie clip (copy frames, paste frames inside a new symbol), and then change the size or apply a color effect to the clip. Or, you can change the keyframes directly by using the Edit Multiple Frames feature and select/modify all frames at once.
Jen
http://www.flashthusiast.com
Camren Banks
on Jul 19, 2010 at 5:56:30 pm
Simple answer to a simple question.
Thank you very much.
