Flash keyframes
COW Forums : Adobe Flash
Bailey Kalesti
Flash keyframes
on Jun 10, 2010 at 12:48:11 am
How does one move keyframes for position data in Flash? I have CS4. I would like to move the translate data keyframe, but keep the rotation data for that frame in the same spot. In After Effects, rotation, scale, and position (as well as practically everything else) have their own timeline "lines". In Flash it appears that all animation data is located within one keyframe! Any help would be most appreciated.
Adam Ashby
Re: Flash keyframes
on Jun 13, 2010 at 7:33:07 pm
If you are using a Motion Tween instead of a Classic Tween you can have property keyframes on different frames. Use the Motion editor to edit them.
Adam Ashby
mutli-media artist
© 2018 All Rights Reserved
