Purge Memory
COW Forums : Adobe Flash
Dan Phillips
Purge Memory
on May 19, 2010 at 9:25:12 pm
How do you purge the computers memory in Flash. This was easy in director. You would just attach some code to an on mouse down script and you could purge everything. How do you do the same in Flash? Also is there a way to dynamically do this for resources such as load a video when it is called and then purge it when it is done playing.
© 2018 All Rights Reserved
