HDV aspect ratio
COW Forums : Adobe Flash
jonathan young
HDV aspect ratio
on Apr 22, 2010 at 5:00:11 pm
I have some video that I used FCP to edit it, I use media encoder to encode it to a .flv file,the problem is no matter what I do, when I bring it into my web program, it is way to large, (the video inside the window looks like it is zoomed out to 100% while my video box looks like it is the size of 40%) when I bring it in flash I have tried settings of 440 x 224 I tried it set to exact fit and I tried it to maintain aspect ratio, I also tried it set to 540 X 324 both ways, no luck, I just want a setting that will maintain it's aspect ratio, I exported it from FCP as a animation file then I used compressor and made it a H.264 quicktime, help please !!
thanks
Mike Smith
Re: HDV aspect ratio
on Apr 23, 2010 at 8:28:14 am
If you use file / import / import video with an flv it should import at original size. You can then set it to scale if you want to. But your video may play more smoothly and with less wasted bandwidth if your output file is the size you want to display ...
