 | Problem looping sound on timeline
on Apr 5, 2010 at 4:06:38 pm |
I am playing background music on the timeline, but it ends too soon on a slower PC/connection. I should be able to loop or repeat, but it does not start over. I cant call up the music via AS3 because I am controlling the audio level with keyframes along the timeline in sync with a voice over.
Any ideas why this is an issue? I cant find an answer at Adobe.com
Thanks.
Tony W
 | Re: Problem looping sound on timeline on Apr 5, 2010 at 4:42:27 pm |
If you want the music to sync with the v/o, you could mix them into one track with the levels as you want ...
 | Re: Problem looping sound on timeline on Apr 5, 2010 at 5:19:15 pm |
True, but the VO may not end up in sync with the animation. As a matter of fact, the VO is chopped up in may different places and needs to remain independent of the bg music. The Adobe PDF does mention using shorter music clips for looping, and my music clip waveform continues beyond the end of my timeline. Perhaps I should shorten the music, but I am starting to grasp at straws.
Adobe, you need to fix this one. The features are under sound properties and should behave as expected.
Tony W
