Custom Ease Curve
COW Forums : Adobe Flash
Tom Slattery
Custom Ease Curve
on Feb 25, 2010 at 7:28:56 pm
Hi!
I use this kind of fast-then-slow ease curve a lot and would like to save it as a custom ease, but cannot find where to do that.
~TPS
Jen deHaan
Re: Custom Ease Curve
on Mar 4, 2010 at 11:04:51 pm
Hi there,
There isn't a feature for saving just an ease (yet - definitely high on the list). You can copy and paste ease curves between tweens, or you can save the custom ease within a motion preset, and then copy and paste from the preset when you need it. If you apply the entire motion preset it will also add the ease, but adjust other properties -- so if you do it that way, make sure you apply it to the new instance intiially so you can adjust it further as needed.
Also, your custom ease is a lot like the "Stop and Start" preset, so you may want to see if that'll work for some of the animations to save a step :)
Jen.
Jen
http://www.flashthusiast.com
