Fullscreen playback issue
COW Forums : Adobe Flash
Dan Phillips
on Feb 22, 2010 at 9:30:19 pm
Writing because we are running into an issue with a project and was hoping someone might know of a solution. Below you will find a link to the FLA and supporting files for the project as well as an exe of the program. The exe program runs just fine if it is run in the window that comes up when the exe is open. However, if we make that window go fullscreen the two videos that are linked to the “data archive” and “motion” buttons respectively will not play correctly. Depending on how they are brought into the program they might not play at all in fullscreen, they might double up audio from another source, they might play but not respect the end command telling them to go back to the main screen, etc. In this attached example they just don’t play in fullscreen. This is on multiple tested systems. We have tried linked FLVs, linked swfs with embedded flvs, linked swfs with linked flvs and I think directly embedded flvs but am not sure on that one. The weird thing is that the other videos of the rotating background play fine when in fullscreen. I would be forever grateful if you could give any insight into what is causing our fullscreen issues.
Pin is 67727
© 2018 All Rights Reserved
