COW Forums : Adobe Flash
nallib said tala montenegro
on Feb 15, 2010 at 8:50:05 pm
how good is the security in flash-php-mysql comunication ?
Mike Smith
Re: flash-php-mysql
on Feb 16, 2010 at 9:51:00 am
Security will rest with you.
Php pages can be set up to work reasonably securely with mysql - level of security probably depends on how valuable your target is and how much effort you will put in. You'd probably want at least a dedicated web server (not a shared hosting effort) for anything with much value. The Flash to php communication is not going to be secure.
If you host on a secure server (https) then you will have encrypted communication between Flash and php, but the Flash swf file itself remains vulnerable to attack, decompiling. (It's not just Flash. Anything running client-side, in the browser, is likely to be at risk.)
It might be worth your while looking at if you are likely going down this route.
© 2018 All Rights Reserved
