Tryngo to control time between slides
COW Forums : Adobe Flash
Alex Brito
on Feb 6, 2010 at 10:30:25 pm
I am a new Flash CS3 user.
I need do control the time between slides, but i can't find a way.
Can someone help me?
Best regards
Brodd Nesset
Re: Tryngo to control time between slides
on Feb 8, 2010 at 12:31:59 pm
This may be more elaborate than what you're asking for. However it is a robust piece of code that takes height for user interaction etc.
Usage: paste the code below into a frame early in your app. Then, in the Timeline, anywhere you need a pause, just type pause(4); for a four second pause. You can even use a decimal number, i.e. 2.6 etc.
function pause(secs:Number):void {
var startFrame:int = currentFrame;
var myTimer:Timer = new Timer((secs * 1000), 1);
myTimer.addEventListener(TimerEvent.TIMER, fResume);
function fResume(e:TimerEvent):void {
myTimer.removeEventListener(TimerEvent.TIMER, fResume);
myTimer = null;
if (currentFrame == startFrame) {
Not everything that can be counted counts, and not everything that counts can be counted.
© 2018 All Rights Reserved
