CS3 file will not open in CS4
COW Forums : Adobe Flash
Drew Morey
on Jan 19, 2010 at 8:10:08 pm
I have a CS3 file that will not open in CS4.
I need to get this file opened by someone who uses CS4 so they can fix it for me.
There is AS2 as well as AS3 in the file, and someone has suggested that this may be the problem. There are hundreds of lines of AS2 code that are time consuming to find and delete.
Can anyone suggest a workaround solution to getting the file open in CS4 that does not involve removing the CS2 code line by line?
© 2018 All Rights Reserved
