Sync two external files to start together using AS3
COW Forums : Adobe Flash
Graham Calhoun
on Jan 16, 2010 at 10:53:36 pm
Hi all,
Here's the issue: I've got a swf which uses AS 3 to load separate audio (mp3) and video (flv) files. The reason they're separate is because the audio is just background music while the video is navigatable. The video kinda goes along with the audio, but it's not imperative that the two sync perfectly. However, the audio always starts playing before enough of the video has loaded to begin streaming.
I'm at a loss as to how to get the two to at least START at the same time. Can someone point me in a direction?
PS. I'm still a beginner at AS 3, so be gentle with the explanations!
Graham
Marcus Geduld
Re: Sync two external files to start together using AS3
on Jan 19, 2010 at 12:15:54 am
How are you playing the video? Are you using the FLVPlayback component?
Author "After Effects Expressions"
Co-author "After Effects For Flash, Flash For After Effects"
Artistic Director, Folding Chair Classical Theatre, Inc
Senior Flash Developer, Zeitbyte.com
