Edit Web Gallery Created From Bridge CS4
COW Forums : Adobe Flash
Mohamad Fadzly Kambari
on Jan 14, 2010 at 8:24:57 am
Hi All,
I have created a flash web gallery from Bridge Cs4. Its plain and simple to use and it looks great.
Now i need to port over this web gallery over to Lotus Notes domino. I have change the paths in which the gallery is pointing to the images invovled.
I can get the gallery to come up. But the pictures are not loading. i tried changing the paths in the xml file that is generated but the images are still not loading. Am i missing out something here?
Or does the swf file embed or hard code the paths in the swf file which in this case i can't change right?
I have been looking at the html and codes for days and i still can't figure it out.
Anyone can help? Appreciate it!
Rachna Reddy
Re: Edit Web Gallery Created From Bridge CS4
on Jan 14, 2010 at 9:33:24 pm
Have you tried placing the AC_RunActiveContent.js file in the respective location? Usually in a Scripts folder on the root location.
I have come across similar problems. But when I uploaded the images to the server and gave the complete URL for each image, it all showed up fine.
Good luck!
© 2018 All Rights Reserved
