One Button Add and Remove Symbol From Stage AS3
COW Forums : Adobe Flash
Jay Mas
on Dec 2, 2009 at 10:10:22 pm
Just want to know the basic code to add a symbol to the stage from the libray and to remove the symbol from the stage with one button.
Basically for example I have one button on the stage and one symbol in the library and I want to bring out the symbol to the stage with a click and then with another click remove the symbol from the stage and if I were to click it again it would bring the symbol back out ect ect.
Is there a small code block in AS3 for this?
demetri tashie
Re: One Button Add and Remove Symbol From Stage AS3
on Dec 2, 2009 at 10:45:20 pm
as long as that symbol has a linkage identifier, it is quite easy. if it does not have a linkage identifier, then in the Library, select the symbol, and either click on the "i"(information) button on the bottom, or right click to get the Symbol Properties dialog box. click Linkage: Export for Actionscript, and the Class name should automaticlaly fill in . hit OK, then OK again when the warning box appears. now you use this linkage name to add the symbol to the stage/Display List
in your button function write this { addChild(symbolLInkageClassName) }
give it X and Y values to positionit if necessary.
use removeChild(symbolLInkageClassName) to remove it.
if what i think you are also asking is to use the same button to add it , then remove it -
there are several approaches to do this. one is to have the first function also remove its EventListener, and then add a new listener with the function of removing the symbol ( this function would then likewise also remove its listener, and restore the original listener)
other ways involve declaring a Boolean value and using a conditinal statement to track it.
Marcus Geduld
on Dec 3, 2009 at 12:15:32 am
If I'm reading that right, it's close but not exactly right.
To bring an instance of a Library Symbol to the stage, you first have to check its Export for Actionscript option, as Demetri described above.
In your code, you create a variable to hold the instance:
var myStar : Star = new Star();
I'm assuming your Library Symbol is called Star. myStar will be the name of the instance I'm about to add to the stage.
Then, to add it to the stage, you type this:
addChild( myStar );
In your button handler, you write...
removeChild( myStar );
Author "After Effects Expressions"
Co-author "After Effects For Flash, Flash For After Effects"
Artistic Director, Folding Chair Classical Theatre, Inc
Senior Flash Developer,
Lisa Pawson
on Mar 1, 2010 at 10:04:40 am
I am having trouble with removeChild, I have added my classes in my FLA file and in the classes it opens a swf file over the original, when this happens I need to remove my classes because some of the components are still left on stage, how could I do this? I have been struggling with this for weeks?
© 2018 All Rights Reserved
