load ASP into flash
COW Forums : Adobe Flash
Aisha Nelson
load ASP into flash
on Nov 23, 2009 at 8:36:32 pm
I am trying to create a member login for my website. The login, register etc pages are already created using ASP.net. How do I import that data into flash?
Mike Smith
Re: load ASP into flash
on Nov 24, 2009 at 10:32:37 am
Flash works in the user's browser, and needs to be coupled with server-side programming (and perhaps a secure server) for any kind of secure application.
At a simple-t-implement level, you could continue with your asp approach, and when logged in allow access to a directory or directory structure secured with .htaccess, where your Flash pages could rest.
If you want to put a Flash visual front end talk to your asp pages, then you'll need to get to work on Flash forms. If programming is all new to you and you need this in a business timescale, it may pay you to commission a developer to do what you need.
Otherwise, a few tutorials that might help you get started:
http://www.golivecentral.com/pages/txttut/htacc.shtml
http://www.adobe.com/support/flash/applications/creating_forms/
http://www.smartwebby.com/Flash_and_ASP/Flash_sends_data.asp
http://www.actionscript.org/forums/showthread.php3?t=158214
Aisha Nelson
on Nov 24, 2009 at 8:29:35 pm
Thanks Mike. Programming is very new to me, however they want me to learn it so we don't have to outsource.... I'm gonna take a look at the tutorials you've listed.
