HELP! can't stop flv
COW Forums : Adobe Flash
Hoss Sarbaz
on Nov 20, 2009 at 12:37:49 am
Hi all I created a slide show which loads a different external swf video when going to the next or previous frame.
but I want it to stop playing the flv when clicking to next or previous frame.
Please help thanks!
Here is my code:
//---start code----//
stop();
prev_btn.addEventListener(MouseEvent.CLICK, prevClick);
next_btn.addEventListener(MouseEvent.CLICK, nextClick);
function nextClick (event:MouseEvent): void
if(this.currentFrame == this.totalFrames)
gotoAndPlay(1);
else {
nextFrame();
function prevClick (event:MouseEvent)
if(this.currentFrame == 1)
gotoAndPlay(this.totalFrames);
else {
prevFrame();
//----stop code----/
can someone please help thanks!
demetri tashie
Re: HELP! can't stop flv
on Nov 20, 2009 at 2:12:23 am
i'll assume you are using a FLVPlayback component . then you just simply tell it to stop when you want - in your case upon either button click. the additional code looks like this. note that i cahnged your previous function from go to and play to go to and stop . you should probablay change the next function likewise - better coding
stop();
flvPlayer.source="myVideo.flv";
flvPlayer.autoPlay=true;
{ flvPlayer.stop();
gotoAndPlay(1);
else {
nextFrame();
{ flvPlayer.stop();
gotoAndStop(this.totalFrames);
else {
prevFrame();
