Help with Style dynamically loaded text
COW Forums : Adobe Flash
sandra schmitt
on Nov 18, 2009 at 5:55:23 pm
hi,
I am trying to style some dynamically text. I have a css stylesheet attached and it is partially working. I got my links to works but now I am trying to just add a little space below my h1 tag and I can't get it to work. When I add the tag I am able to change font size but I can't get the line-height style to work. Even when i dont put the line-height property in there it leaves a giant space between header and link entry. I just want there to be a little space.
Right now in my txt doc I only have the header tag attached to the first h1 headers/states.
I am attaching link, text, and code. I am not good with tags and style sheets.
ANy clues???
Thanks in advance for time :)
Sandra
link:
http://www.sandraschmitt.com/coclico/index102.html
CSS Style sheet:
h1
color:#333333;
font-size: 10pt;
line-height: 12pt;
a
color:#333333;
a:hover
text-decoration:underline;
txt doc:
<h1>ALABAMA</h1>
<a href="http://www.abbeyluxe.com" target="_blank">Abbey Luxe</a>
<h1>CALIFORNIA</h1>
<a href="http://www.americanrag.com" target="_blank">American Rag</a>
<a href="http://www.crimsonmim.com" target="_blank">Crimson Mim</a>
<a href="http://www.deliciouz.com" target="_blank">Deliciouz</a>
<a href="http://www.gimmeshoes.com" target="_blank">Gimme Shoes</a>
<a href="http://www.lesdeuxcopines.com" target="_blank">Les Deux Copines</a>
<a href="http://www.margaretoleary.com" target="_blank">Margaret O'Leary</a>
<a href="http://www.rabatshoes.com" target="_blank">Rabat</a>
COLORADO
<a href="http://www.shopscarpe.com" target="_blank">Scarpe</a>
<a href="http://www.strutdenver.com" target="_blank">Strut</a>
GEORGIA
<a href="http://www.pellashoesatlanta.com" target="_blank">Pella</a>
<a href="http://www.sabotshoes.com" target="_blank">Sabot</a>
ILLINOIS
<a href="http://www.citysoles.com" target="_blank">City Soles</a>
<a href="http://www.shirise.com" target="_blank">Shirise</a>
KANSAS
<a href="http://www.habitatshoes.com" target="_blank">Habitat</a>
MASSACHUSSETTS
<a href="http://www.louisboston.com" target="_blank">Louis Boston</a>
NEBRASKA
<a href="http://www.denizshoes.com" target="_blank">Deniz</a>
NEW JERSEY
<a href="http://www.primadonnaboutiques.com" target="_blank">Primadonna Boutiques</a>
NEW HAMPSHIRE
<a href="http://www.heiumshoes.com" target="_blank">Heium Shoes</a>
NEW YORK
<a href="http://www.kaightnyc.com" target="_blank">Kaight</a>
<a href="http://www.taninnyc.com" target="_blank">Tani</a>
<a href="http://www.vervenyc.com" target="_blank">Verve</a>
PENNSYLVANIA
<a href="http://www.joanshepp.com" target="_blank">Joan Shepp</a>
TEXAS
<a href="http://www.bygeorges.com" target="_blank">By George</a>
<a href="http://www.gottahavemypumps.com" target="_blank">Gotta Have My Pumps</a>
VERMONT
<a href="http://www.stella-shoes.com" target="_blank">Stella Shoes</a>
Mike Smith
Re: Help with Style dynamically loaded text
on Nov 18, 2009 at 6:14:34 pm
If you're successfully importing the style sheet and getting your dynamic text to format as html, you could try using
margin-bottom: 0.5em ;
or similar inside your h1 style declaration.
Personally, I think there's a case for using ems rather than pixels all over in straight (x)html , though inside Flash it may all be quite different
sandra schmitt
on Nov 18, 2009 at 6:25:00 pm
thanks!! I will try that!
sandra
