AS2 Conflicting Scripts
COW Forums : Adobe Flash
matt short
on Nov 14, 2009 at 5:54:39 pm
I've built 2 scrollbars w/text side by side and I have 2 AS on different layers to control each. The problem is both scrollbars control the text window of the AS which is on the bottom (layer in the timeline).
Here's the top AS...
fscommand("allowscale", "false");
bar2.useHandCursor = dragger2.useHandCursor=false;
space = 20;
friction = 0.9;
speed = 4;
y = dragger2._y;
top = newsTXT._y;
bottom = newsTXT._y+mask_mc2._height-newsTXT._height-space;
dragger2.onPress = function() {
drag = true;
this.startDrag(false, this._x, this._parent.y, this._x, this._parent.y+this._parent.bar2._height-this._height);
dragger2.scrollEase();
dragger2.onMouseUp = function() {
this.stopDrag();
drag = false;
bar2.onPress = function() {
drag = true;
if (this._parent._ymouse>this._y+this._height-this._parent.dragger2._height) {
this._parent.dragger2._y = this._parent._ymouse;
this._parent.dragger2._y = this._y+this._height-this._parent.dragger2._height;
} else {
bar2.onMouseUp = function() {
drag = false;
moveDragger2 = function (d) {
if ((dragger2._y>=y+bar2._height-dragger2._height && d == 1) || (dragger2._y<=y && d == -1)) {
clearInterval(myInterval);
} else {
dragger2._y += d;
updateAfterEvent();
up_btn2.onPress = function() {
myInterval = setInterval(moveDragger2, 18, -1);
down_btn2.onPress = function() {
myInterval = setInterval(moveDragger2, 18, 1);
up_btn2.onMouseUp = down_btn2.onMouseUp=function () {
MovieClip.prototype.scrollEase = function() {
this.onEnterFrame = function() {
if (Math.abs(dy) == 0 && drag == false) {
delete this.onEnterFrame;
r = (this._y-y)/(bar2._height-this._height);
dy = Math.round((((top-(top-bottom)*r)-newsTXT._y)/speed)*friction);
newsTXT._y += dy;
And here's the bottom AS...
bar.useHandCursor = dragger.useHandCursor=false;
space = 20;
friction = 0.9;
speed = 4;
y = dragger._y;
top = eventsTXT._y;
bottom = eventsTXT._y+mask_mc._height-eventsTXT._height-space;
dragger.onPress = function() {
drag = true;
this.startDrag(false, this._x, this._parent.y, this._x, this._parent.y+this._parent.bar._height-this._height);
dragger.scrollEase();
dragger.onMouseUp = function() {
this.stopDrag();
drag = false;
bar.onPress = function() {
drag = true;
if (this._parent._ymouse>this._y+this._height-this._parent.dragger._height) {
this._parent.dragger._y = this._parent._ymouse;
this._parent.dragger._y = this._y+this._height-this._parent.dragger._height;
} else {
bar.onMouseUp = function() {
drag = false;
moveDragger = function (d) {
if ((dragger._y>=y+bar._height-dragger._height && d == 1) || (dragger._y<=y && d == -1)) {
} else {
dragger._y += d;
updateAfterEvent();
up_btn.onPress = function() {
myInterval = setInterval(moveDragger, 18, -1);
down_btn.onPress = function() {
myInterval = setInterval(moveDragger, 18, 1);
up_btn.onMouseUp = down_btn.onMouseUp=function () {
r = (this._y-y)/(bar._height-this._height);
dy = Math.round((((top-(top-bottom)*r)-eventsTXT._y)/speed)*friction);
eventsTXT._y += dy;
matt short
Re: AS2 Conflicting Scripts
on Nov 14, 2009 at 10:31:00 pm
Problem Solved
