Flash export to QT issues
COW Forums : Adobe Flash
justin lee
on Nov 2, 2009 at 10:12:26 pm
so i have a 25 second flash cs3 file and i want to export a regular Quicktime
the export ends up being over a minute long
and i can't figure out why
i'm using the H.264 codec with best quality at 30 frames per second
after screwing with settinga, i can't come to an answer
suggestions??
Aaron Kiersky
Re: Flash export to QT issues
on Nov 11, 2009 at 4:24:55 pm
check your project properties, the default for new projects is 12fps. So, if you are creating 30fps video from a 12fps project; 25 seconds @ 12fps ~ 62.5 seconds @ 30fps
good luck
