H264 vs On2
COW Forums : Adobe Flash
Thomas Ernst
H264 vs On2
on Oct 23, 2009 at 3:43:41 pm
I'm using CS3 and trying to get an flv file closer to 10 megs if I can--currently the file is 14 megs, 640x480, 800mbps, keyframe@30; audio comp @ 96, using the On2 codec. The quality is about as low as I want to go. Is the H264 codec significantly more efficient--can I expect to knock off a few megs with similar settings?
I've avoided upgrading to CS4 but if it will help in this case I will.
Adam Ashby
Re: H264 vs On2
on Oct 26, 2009 at 5:23:40 am
H.264 will definitely knock off a few megs and be better quality. You don't need to upgrade to CS4. You just need to an app to compress to H.264. It can even be a QuickTime file. Yes, Flash can play QuickTime movies, they don't have to be flv or f4v. That is unless you need the metadata information in them that Flash can read.
Adam Ashby
mutli-media artist
© 2018 All Rights Reserved
