Can flash do this?
COW Forums : Adobe Flash
Fitz Aguilera
Can flash do this?
on Oct 13, 2009 at 2:02:51 am
I am not familiar with flash that's why I am going to ask this:
Above link is a way to view 3d objects in flash in which you can rotate and tilt a still object.
BUT I am into 3d animation of human figures.
Since this is an animation and are not stills, I need to know if flash can let me scroll through animations, where the models pieces are moving as you drag forward or backwards, but also the ability to look at the model through rotation.
I am thinking of rendering an image sequence of a 360 view of a horizontal/vertical etc. of an animation, import it to flash and make flash combine the images creating a pseudo3d effect. Most importantly, the rotation/play/pause/speed should be able to be controlled interactively.
Can flash do these?
© 2018 All Rights Reserved
