AS3 Flash Navbar Problem
COW Forums : Adobe Flash
sandra schmitt
on Sep 29, 2009 at 6:31:21 am
I am trying to make the buttons work in this simple horizontal flash navbar. I know how I would make this work in AS2 but I am really trying to update myself to AS3 and really having hard time. Basically I have the first layer of navigation working so tat when you click on them a submenu appears underneath. I am having trouble making the sub buttons work. I tried to use same code as on top layer of navigation but I keep getting a null error. For some reason the sub-buttons under the first section "collections" worked, but when I try to do the same thing for the sections I get the error. Any help would greatly be appreciated. I didn't add the other button functions to the code because anytime I tried to add more that's when I got the error.
Thanks again!
Here is the link:
here is the code that I have in the first frame of my flash doc:
function goCollections(e:MouseEvent):void {
collections_btn.addEventListener(MouseEvent.CLICK, goCollections);
function goRaison(e:MouseEvent):void {
raison_btn.addEventListener(MouseEvent.CLICK, goRaison);
function goStores(e:MouseEvent):void {
stores_btn.addEventListener(MouseEvent.CLICK, goStores);
function goNews(e:MouseEvent):void {
news_btn.addEventListener(MouseEvent.CLICK, goNews);
function goContact(e:MouseEvent):void {
contact_btn.addEventListener(MouseEvent.CLICK, goContact);
function goSpring(e:MouseEvent):void {
spring_btn.addEventListener(MouseEvent.CLICK, goSpring);
© 2018 All Rights Reserved
