AS3 flvplayback component fullscreen won't work!!
COW Forums : Adobe Flash
rachel goldstein
on Sep 21, 2009 at 5:14:38 pm
I have a couple of different FLV's set up in different frames using flvplayback component and a button set up for nextframe and another for prevframe to go back and forth. Everything works fine until you go into fullscreen mode and the the screen goes black when you change frame and the flv is gone if you press esc to return to normal mode.
Any help would be appreciated, I have searched google all day for help!
A stripped down version of my site here:
http://www.jrachdesign.com/thatslife/thatslife.html
Here is the FLA:
http://www.jrachdesign.com/thatslife/video.fla
Amy Harvey
Re: AS3 flvplayback component fullscreen won't work!!
on Dec 14, 2009 at 8:06:47 pm
Hi, I realize this is an older post but I am running into the same problem and wondering if you have ever solved it? It is very frustrating because I see lots of posts from people who have encountred it but no real solution.
